![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
So does the pedal still go down to the floor even though it won't disengage or does it have resistance?
I'm a hermit named Lee |
#2 | |
![]() Drives: Yaris MY2010 1.33l SOL 5d Join Date: Sep 2021
After bleeding it almost empty until it did not push anything out anymore, the pedal was very lose and easy to push down, I refilled it from the bottom (bleeding valve / nipple) to prevent air bubbles. Pedal works now normal but clutch does not disengage (like before the bleeding / changing the fluid) No drops under the car, no liquid from the reservoir disappearing...
| Tags |
| no clutch |
| Clutch shudder when setting off in 1st gear | BuildCode | DIY / Maintenance / Service | 87 | 06-17-2015 07:14 AM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 05:20 PM |
| Yaris sedan low and high beam | jorizk | DIY / Maintenance / Service | 10 | 03-02-2010 09:49 AM |
| engine revs when clutch depressed | Yaris#2 | General Yaris / Vitz Discussion | 7 | 02-20-2010 10:28 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
