Old 10-05-2021, 09:44 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Unlikely. The Echo uses the C150, the Yaris uses the C50. Key differences could include some or all of the following: mounting points, shaft splines in the differential, cable linkages, wire connectors. The engine block, starter and torque converter/flex plate should line up but that's about all that is likely to mate without serious modification.
2005 echo rs steering wheel compatible with 2007 yaris??? Xlt00 Cosmetic Modifications (Exterior/Interior) 2 01-11-2018 04:53 PM
Toyota Yaris 2005 semi auto doesn't start nihad DIY / Maintenance / Service 0 10-26-2017 04:16 PM
