Old 10-23-2021, 06:13 PM   #1
Ecefour
Drives: 2007 Yaris Hatch
Thanks for the tutorial! So, i dont want to touch the wiring in my car. I just like to have everything easily reversible. But In theory I could just buy a male tachometer connector and wire in the tachometer that way? Then it would easily removable.
I've looked online and I haven't been able to found an OBD tachometer that is JUST a tachometer. Most of them are HUDs that display RPM along with other information that I dont care about. Also the last HUD i tried had horrible latency.
Ecefour is offline   Reply With Quote
Old 04-22-2022, 01:45 AM   #2
2010yarisHBbase
Drives: 2010 toyota yaris hatchback
I understand not wanting to touch the wiring and I only did it because I learned enough and trusted myself not to fk it up :D ofc there are lots of obd connected tachs but those like you experienced are very laggy and delayed with the tach information because it is through the obd. and I have yet to see a long lasting one that is affordable and efficient. That's why I decided to tap into the wires because I wanted instant feed back and it was worth it. everything I did was reversible esp since I only glued the tach with cheap double sided tape. The wiring is also removable but ofc there is always that lil bite mark where the connecters bit.
2010yarisHBbase is offline   Reply With Quote
Tags
installation, tachometer, tutorial, yaris
2014 Yaris LE Fog lights installation help. Eforno DIY / Maintenance / Service 0 01-05-2016 07:20 PM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 03:14 PM
installation of a front bumper to a yaris rs 2000 Andreas Cosmetic Modifications (Exterior/Interior) 3 09-17-2009 12:42 AM
