Old 10-27-2021, 07:10 AM   #1
ex-x-fire
They can be tough, the ball joint stud is usually held tight in the knuckle while you unthread the nut. I'd soak it for a while, if you have a torch then you can heat the nut up.
Old 10-28-2021, 03:51 AM   #2
CrimsonEclipse
Drives: .
Used a vice grip. Destroyed the boot in the process.
Now the forward bolt hits the engine block and can't be removed.
Oh, Toyota, you so crazy.
CrimsonEclipse is offline   Reply With Quote
Ball Joint Warning tmontague Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-31-2024 08:39 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Warning - Broken control arm bolt! CB900F2 DIY / Maintenance / Service 460 08-23-2020 05:54 PM
2007 hatch front passenger ball joint Phatdonkey78 DIY / Maintenance / Service 4 02-16-2019 11:56 AM
Ball Joint on Bottom Arm David Godfrey DIY / Maintenance / Service 1 04-18-2010 06:27 PM
