Old 11-02-2021, 02:59 PM   #1
The problem is usually corrosion buildup on the wired sensor the connects to the hub, not an issue with the hub. Do some searching here. There are many instances where people have had success cleaning the sensor and applying liberal amounts of dielectric grease before reconnecting.
Old 11-02-2021, 03:09 PM   #2
Reklaw-79
Drives: Yaris TR
When you say clean the sensor do you mean the harness plug and sensor plug?
Reklaw-79 is offline   Reply With Quote
HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! mizhgolightly DIY / Maintenance / Service 45 05-03-2022 02:59 PM
Toyota Yaris 2002 ABS and ! Light Rihsky DIY / Maintenance / Service 3 12-01-2015 09:16 AM
Yaris 2007 ABS & Brake light issue after wheel bearing change DevilzMafia DIY / Maintenance / Service 4 01-17-2013 09:24 PM
Brake & ABS Light On JeffRapp DIY / Maintenance / Service 3 01-04-2013 11:10 PM
Toyota Yaris -06 VCC and ABS light went on? goedafred DIY / Maintenance / Service 4 03-01-2011 12:22 AM
