Old 11-27-2021, 12:44 PM   #1
IndestructibleYaris
To identify a performance issue, add fuel or subtract fuel and see what happens. Do a cylinder drop test. You're gaining clues as to whether it's fuel, spark, compression, or timing related. Since you have a code for intake air valve I'd go there first with a diagnosis. I'm sure you can test the idle air control valve with just a battery and some wire. You can cause a vacuum leak and see if it improves, if so I'd just gamble with a new iac
IndestructibleYaris is offline   Reply With Quote
Tags
engine help, rough idle, sensors, shift, stalling
