Old 12-16-2021, 08:07 AM   #1
janosik7788
Drives: Yaris 2009, 5D 1,33 VVTi 74kW
P2196 A/F sensor problem
Originally Posted by Saphe View Post
Thanks SirDigiby.
I started with cleaning and clearing the sensor connectors with Electric cleaner and this without successivt. No Light came on my way to work (25 km) but driving home did Light it up after 20 minutes of driving :( i dont get any symptoms more then check engine light. My thoughts has also been on looking into the mass Air flow sensor so i will do that and check the air filter. If still the problems occurs then my last step will be buying a new a/f sensor - toyodiy homepage gives me part number 89467-52070
I will se if i find denso in first hand before looking at other producers :)
Thank you for your advice :) i will be putting in the outcome when im done. Will take a while before reposting :)
Hi there, I am having the same issue just know, first it happened on april this year, but now in last 3 weeks I had P2196 error.
I have bought new A/F sensor Denso DOX-0269 - but then shortly after the restart I got error message code P0031. We have checked both of the sensors, the resistance was there. Then I returned the new sensor to the shop and for now I am on the old one after clearing P0031 it was ok. But after 100km again P2196.
Any hints or thoughts guys?
Any help appreciated!
Thank you
Joe
@Saphe How did it finish in your case?
janosik7788 is offline   Reply With Quote
DIY : changing the Oxygen / O2 sensor on Yaris hatch MANY PICS auxmike DIY / Maintenance / Service 50 12-10-2024 12:39 PM
ABS and "!" lights are ON again! onizuka Canada 457 04-28-2023 09:40 AM
The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) Darb Off-topic / Other Cars / Everything else Discussions 86 10-18-2017 08:03 AM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
