Old 02-03-2022, 04:46 PM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Hi Chris,
Obvious question, but have you allowed for the Yaris not having an automatic tensioner on the belt? You need to loosen off the alternator to fit the new belt. Be careful, as the control valve for the variable valve timing is behind the alternator. It's right where you would normally place a lever while tensioning the new belt.
Adjusting drive belt tension questions Rob888 General Yaris / Vitz Discussion 2 10-01-2021 03:09 PM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
Auxiliary drive belt change fredsyaris DIY / Maintenance / Service 0 06-30-2017 12:05 PM
Accessory belt starting to "slit" horitzontally........ Yawesh General Yaris / Vitz Discussion 40 10-09-2009 09:34 AM
Test drove Rio5, Fit, and Yaris all today kmf123kmf New YARIS Purchase Forum 16 10-02-2009 07:48 PM
