Old 05-14-2022, 08:14 PM   #1
sh0rtlife
if its not too much of a pain...unbolt the passenger motor and plug it into the dirvers side, if it works you know its the driver motor..if it fails to work, youve got a wiring issue
Old 05-19-2022, 04:04 PM   #2
Welshpear
Drives: Yaris
Finally sorted the problem. It was the broken wiring in the harness going through the door hinge.
Welshpear is offline   Reply With Quote
Old 05-23-2022, 04:15 PM   #3
sh0rtlife
sadly thats the typical spot for MOST cars with power anything in the doors..had that issue in the 90s on my 74 lincoln, fixed that issue around 2001 on an 80s accord...
every time you open your doors you flex all the wires going into them
DIY - OEM Power Window Conversion CTScott DIY / Maintenance / Service 29 10-27-2024 11:02 PM
Anyone having trouble finding a 2015 Yaris at a local dealer. Zombiesrock Third Gen Yaris General Discussion 6 12-30-2015 12:52 PM
October 2015 Yaris Sales: Down Thirty-Nine General Yaris / Vitz Discussion 3 12-05-2015 05:59 PM
