Old 05-15-2022, 12:27 AM   #1
CrimsonEclipse
Drives: .
You have my respect.
I'd rather change the engine than replace an evaporator.
CrimsonEclipse is offline   Reply With Quote
Old 05-15-2022, 01:16 AM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
+1
Lots of good info and pictures here for the next guy. Well done.
Old 05-15-2022, 02:58 PM   #3
sh0rtlife
honestly tho its EASY "light" work and only took 2 hours to get out and another 2 to get it back in, and i also did some re-routing of fog lights, usb hookups, and wired it for cruise
all said the biggest pain in the job is the steering colomn piviot bolt which requires dissconnecting the brake arm from the master rod, and even then getting that bolt out is a TIGHT fit, otherwise the only other snag bit is fishing the box out the passenger side of the car as you hold up the cross bar..a second set of hands would have made that simple
2007 Yaris Engine Swap tmtab8588 Performance Modifications 2 12-29-2017 01:32 AM
2007 and 2015 parts swap yak General Yaris / Vitz Discussion 4 04-02-2016 01:43 PM
2012 dash swap 2007 yawly Cosmetic Modifications (Exterior/Interior) 15 03-15-2014 11:57 PM
