Old 05-19-2022, 11:07 PM   #1
xdarkxfirex
Drives: 2015 yaris le
Originally Posted by mitch9521 View Post
I have an aluminum one on my car that I got from Aliexpress, it cost under 30 bucks and is actually good quality. Just be careful when working around it if the engine is hot as the aluminum holds a lot of heat(way more than the plastic one) and will burn your arm, I know from experience.
I got one with AliExpress. I noticed glue around where the overflow hose attached. Is yours like that? The listing pictures dont seen to have that on the one I ordered but all the others do. I hope that won't be a failure point for them in the future. I expected it to be on solid piece
xdarkxfirex is offline   Reply With Quote
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
What is a (or the) coorect coolant & amount for a Yaris? RMcG DIY / Maintenance / Service 0 06-19-2019 05:36 PM
Removal of petrol filler neck and wheel arch welding SilverChariot DIY / Maintenance / Service 1 06-18-2017 07:44 AM
Coolant Level in filler neck? CB900F2 DIY / Maintenance / Service 26 05-18-2014 05:09 AM
toyota yaris sedan, missing flap just inside fuel filler neck 41magmag41 General Yaris / Vitz Discussion 3 10-17-2010 04:43 PM
