Old 05-24-2022, 04:05 AM   #1
komichal
Hats off to you sir, this is some serious work!
By the way - does the cool air start to blow instantly after you turn on the AC, even in very hot conditions?
My AC sometimes takes literally 5 minutes to start blowing cold air, espacially when the outside is awfully hot and the car sat overnight on the parking lot.
I asked the dealership to check - they added little bit of refrigerant and measured the pressures - all was OK and they were not able to find a problem. They changed the pressure switch "for preventive purposes" but no help. Could it be that the whole AC system is just worn out after 15 years of service?
Old 05-24-2022, 07:33 PM   #2
sh0rtlife
ive yet to have it hot enough outside to put it "thru the ringer" to so speak
however at 79-82 with some humidity it blows ice cold in say 30 seconds or so
i do have some further notes im about to post tho that may help
2007 Yaris Engine Swap tmtab8588 Performance Modifications 2 12-29-2017 01:32 AM
2007 and 2015 parts swap yak General Yaris / Vitz Discussion 4 04-02-2016 01:43 PM
2012 dash swap 2007 yawly Cosmetic Modifications (Exterior/Interior) 15 03-15-2014 11:57 PM
