Old 06-03-2022, 02:04 PM   #1
sh0rtlife
the brain needed to re-learn what it was attached to, its kinda common for ALOT of parts on new cars to need to do that
Old 06-07-2022, 08:50 PM   #2
nesagwa
Drives: 2007 Yaris Hatchback (US, MT)
That's what I figured, it's working now so its all good.
Sat and swapped out the bulbs on the climate control knobs today and now everything matches a bit better.
File Type: jpg 285589520_506305021274808_1189629000809211214_n.jpg (90.2 KB, 72 views)
nesagwa is offline   Reply With Quote
cluster, swap
After Engine Swap Downstream O2 Sensor Question 06YarisRS Performance Modifications 10 12-22-2018 11:16 PM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 08:12 PM
1nzfe throttle body swap and fitment questions EchoBob02 Performance Modifications 14 05-01-2014 08:02 AM
Do you really need the 1nzfe cluster when doing a swap? longlivekel DIY / Maintenance / Service 5 01-01-2014 06:22 PM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 10:22 AM
