look up how you do the roof on something like vintage camaro...its not the "exact" same job but its still going to be the same procedure and work..just a different shape...
let me be clear, ive done roof replacement on vintage stuff, and if you dont get it right youll taco the roof....i had to redo a 69 barracuda fastback that a pro shop taco'ed when they replaced it...patiance meticulase attention to detail and measuring everything a million times and going SLOW is the only way to get a roof swap right i still cringe at the fact ill have to do my 58 ford and keep back burning it....its an UGLY pain in the rear job, and almost all cars are the same procedure, and id HIGHLY recomend removing ALL of the interior, but DO NOT remove the doors(keep em shut too keeps the body square) as when you start welding cinders will go EVERYWHERE both front and rear glass come out everything keeping the headliner in comes out then you need to seperate the body glue from all the crossmembers of the roof skin after that locate every spotweld along the drip rails and window openings drill all spot welds with the correct spot weld drill bit...expect to drill about 100 spot welds remove replace and re-weld honestly tho unless you have weird damage in weird spots youd be better off pulling the interior and doing the body work massaging to get them out..replacing a roof is a MASSIVE job and not for the faint of heart.....the body work to fix it will run you 1/4 of the time effort and supplys that it would take to just fix the skin thats on it |
#2 | |
![]() Drives: 2010 yaris sedan Join Date: Jun 2022
The ins adjuster actually recommended the roof replacement, thats the only reason I asked. Dunno.
#3 | |
a roof is a structural member so much so its easier to replace an entire floor of a car than it is a roof as the floor is "sectioned" and any heat warping in the welding will never be seen, a lil too much heat in any 1 spot weld in the roof and youll be doing more body work than youd need for the hail damage lets put it another way..unless the cars exceptionaly valuable TO YOU or is something that cant be easily replaced..id NEVER do a roof on a car now with all that said, there are a small handfull of cars where the roof is glued in....like the tesla |
| trunk lock won't turn w/ key - 2010 Yaris Sedan | TYaris2010 | General Yaris / Vitz Discussion | 16 | 09-19-2018 05:16 PM |
| Where to buy service & repair manual? (and Parts manual?) 2010 Yaris Sedan | TYaris2010 | DIY / Maintenance / Service | 1 | 07-08-2018 09:38 AM |
| Yaris Sedan 2010 - OEM Paint or aftermarket? | Kalispel | General Yaris / Vitz Discussion | 3 | 07-09-2015 07:12 AM |
