Old 06-05-2022, 12:51 PM   #1
sh0rtlife
Originally Posted by 2010yaristoyota View Post
Thanks for the reply. I assumed the roof I actually see on top of car was just a panel that was far more simply replaced, drilling out welds and the like sounds like overkill work. Dunno. Will have to do more reading.
The ins adjuster actually recommended the roof replacement, thats the only reason I asked. Dunno.
most agents and adjusters know jack about cars and assume everything is a replaceable part
a roof is a structural member so much so its easier to replace an entire floor of a car than it is a roof as the floor is "sectioned" and any heat warping in the welding will never be seen, a lil too much heat in any 1 spot weld in the roof and youll be doing more body work than youd need for the hail damage
lets put it another way..unless the cars exceptionaly valuable TO YOU or is something that cant be easily replaced..id NEVER do a roof on a car
now with all that said, there are a small handfull of cars where the roof is glued in....like the tesla
trunk lock won't turn w/ key - 2010 Yaris Sedan TYaris2010 General Yaris / Vitz Discussion 16 09-19-2018 05:16 PM
Where to buy service & repair manual? (and Parts manual?) 2010 Yaris Sedan TYaris2010 DIY / Maintenance / Service 1 07-08-2018 09:38 AM
Yaris Sedan 2010 - OEM Paint or aftermarket? Kalispel General Yaris / Vitz Discussion 3 07-09-2015 07:12 AM
