Old 06-13-2022, 01:52 PM   #1
BLH
Drives: 2007 Yaris Sedan
2007, Sedan, Factory Air, 2 speed cooling fan.
Wiring diagram shows a few different setups.
Mine is with defrost switch to enable it to run in the defrost setting, no PTC heater.
Sitting overnight. Cooling and blower fan full on. Radiator cooling fan is running until AC is turned off.
The Fan #1 relay is part of the Integration relay assembly. In the Engine Room fuse and relay box.
Right side of the engine compartment. Fan #2 Relay is also a separate relay in the same location.
If you look down just right of the air cleaner. The is a 1.3 Ohm large white in my case resistor.
I have not seen an active site recently with the service literature for a 2007 lately
BLH is offline   Reply With Quote
Old 06-14-2022, 06:43 PM   #2
sh0rtlife
thanks for that, it atleast helps point me in a direction
looks like the car was born without the resistor as i know the location you speak of and ive got cold air in there and see no resistor
also if the ac is on its not kicking the fan on so ive got something i need to figure out be it telling the ECU that its now got ac or something else
however this car DOES have the PTC heater so maybe that has something to do with it too?
wondering if i need to get the combi relay, and the resistor and whatever wiring goes with it and "add" it to the system...i think theres a couple sedans at the wreckers right now sooo i may be able to source my bits
HD Test: Quick Walk Around The Architect Photo-Video-Media Gallery 4 06-10-2009 01:26 AM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
I finally test drove a Yaris Hatch... ECHOKnight2000 New YARIS Purchase Forum 10 02-01-2007 12:18 PM
