![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
it looks like one of the cluster lovating tabs on the dash is broken, the cluster isnt sitting up in the correct position, happened to me too, i used a paper clip and drilled 2 small holes and shaped a new little tab
| Tags |
| cluster, swap |
| After Engine Swap Downstream O2 Sensor Question | 06YarisRS | Performance Modifications | 10 | 12-22-2018 11:16 PM |
| 06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) | 06YarisRS | Performance Modifications | 448 | 12-06-2018 08:12 PM |
| 1nzfe throttle body swap and fitment questions | EchoBob02 | Performance Modifications | 14 | 05-01-2014 08:02 AM |
| Do you really need the 1nzfe cluster when doing a swap? | longlivekel | DIY / Maintenance / Service | 5 | 01-01-2014 06:22 PM |
| instrument cluster swap S -> LB | elo79 | Performance Modifications | 1 | 12-21-2006 10:22 AM |
