Old 06-14-2022, 06:38 PM   #1
sh0rtlife
speaking generaly here, but the remote wire is little more than a .5amp signal to "switch" on a device be it power antenna or amp, its either going to work or not work, it wont work just "sometimes"
the fact that your switching inputs tells me its a head unit issue, as to why its turning off the amp thats a good question..outside of checking thru options etc its hard to know..it could just be the heads shot
just for giggles you could tap the power wire and jump the amp on and verify if its a "head turning off amp" or head not supplying sound to amp...
Old 06-15-2022, 01:50 PM   #2
Pinchlite
Drives: 2007 yaris HB
what wire would I use to "jump"the amp?
Like I said as soon as I switch to mp3 files that are on a usb stick the amp turns off...the mp3 plays fine over the other speakers just not the sub obviously.
Engine Power problem johnnashfcup DIY / Maintenance / Service 5 12-16-2015 06:40 AM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
aftermarket power lock problem mauiyaris In Car Entertainment + Electronics (audio / video / alarm) 17 08-24-2010 02:40 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
