Old 06-15-2022, 05:58 PM   #1
BLH
Drives: 2007 Yaris Sedan
Thanks for the information.
The stock setup has a AUX Jack mounted on the passenger side of the car center console.
The Amp I was thinking of is the one on the antenna wire to amplify the antenna signal into the radio. It should be turned on by the head when you are using a radio source. If it is not turned on I would expect the reception is poor.
If your sub does not go on at all the times you want it to. It looks like the head itself or the signal to the sub to turn on.
BLH is offline   Reply With Quote
Old 06-15-2022, 06:29 PM   #2
Pinchlite
Drives: 2007 yaris HB
I could check the power antenna/trigger wire has power output with multi...
But then again it must have power if it triggers the amp in radio mode.
Best bet probaly is to try another headunit.
Old 06-16-2022, 09:26 PM   #3
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
This might be different on my series 3, but my diagram shows 2 separate output pins from the radio for the antenna and for an amplifier.
On the 16 pin connector, pin 8 is listed as Antenna, and pin 9 as Amplifier Control.
Looking at the socket on the back of the radio, pin 9 is on the top row, second from the right.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 06-19-2022, 04:33 PM   #4
Pinchlite
I solved it by connecting remote wire from amp to acc from back of headunit wiring.
The remote wire can be any 12 volt source as I just recently learned.
My stereo is wired direct btw with a toggle switch...I do all my stereos like this so I can listen without key turned/car totally off.
Engine Power problem johnnashfcup DIY / Maintenance / Service 5 12-16-2015 06:40 AM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
aftermarket power lock problem mauiyaris In Car Entertainment + Electronics (audio / video / alarm) 17 08-24-2010 02:40 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
