Old 06-17-2022, 12:31 AM   #1
sh0rtlife
the fact your using a "drive thru" oil change place is terrifying..what they used shouldnt even be clasifyed as oil be it conventional or synth....they get the cheepest garbbage they can by the 55gal drum.......
waiting too long wouldnt have cause this, however 170k could be looking at various bad seals..at the very least likely a valvecover gasket
synthetic is better on your gaskets and seals in the "long run" while conventional is better on them in the "short term", id highly reccomend you run valvoline high milage be it synth or conventional
seeing coolant tho i suspect youve got a waterpump on its way out
Old 06-17-2022, 01:47 AM   #2
lightdisc2
Drives: Yaris 2008
I don't always do the drive thru ones, only do sometimes when I need an oil change quickly and because of low income. But yeah I won't go back to one again with this car. Will make sure the water pump gets looked at, too. But couldn't the coolant just be from driving without a serpentine belt? Thanks.
lightdisc2 is offline   Reply With Quote
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Oil and coolant leak jaybowblue DIY / Maintenance / Service 1 08-14-2016 10:41 PM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Lost Serpentine Belt NickNickNick DIY / Maintenance / Service 33 07-31-2011 12:28 PM
