Old 06-19-2022, 04:33 PM   #1
Pinchlite
Drives: 2007 yaris HB
Originally Posted by kevinj93 View Post
This might be different on my series 3, but my diagram shows 2 separate output pins from the radio for the antenna and for an amplifier.
On the 16 pin connector, pin 8 is listed as Antenna, and pin 9 as Amplifier Control.
Looking at the socket on the back of the radio, pin 9 is on the top row, second from the right.
I solved it by connecting remote wire from amp to acc from back of headunit wiring.
The remote wire can be any 12 volt source as I just recently learned.
My stereo is wired direct btw with a toggle switch...I do all my stereos like this so I can listen without key turned/car totally off.
Pinchlite is offline   Reply With Quote
Engine Power problem johnnashfcup DIY / Maintenance / Service 5 12-16-2015 06:40 AM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
aftermarket power lock problem mauiyaris In Car Entertainment + Electronics (audio / video / alarm) 17 08-24-2010 02:40 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
