Old 06-22-2022, 07:00 PM   #7
nesagwa
Drives: 2007 Yaris Hatchback (US, MT)
Originally Posted by remcafee View Post
it looks like one of the cluster lovating tabs on the dash is broken, the cluster isnt sitting up in the correct position, happened to me too, i used a paper clip and drilled 2 small holes and shaped a new little tab
It's been bugging me so I will either drill and put a support or do the ABS glue route soon.
nesagwa is offline   Reply With Quote
Tags
cluster, swap
After Engine Swap Downstream O2 Sensor Question 06YarisRS Performance Modifications 10 12-22-2018 11:16 PM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 08:12 PM
1nzfe throttle body swap and fitment questions EchoBob02 Performance Modifications 14 05-01-2014 08:02 AM
Do you really need the 1nzfe cluster when doing a swap? longlivekel DIY / Maintenance / Service 5 01-01-2014 06:22 PM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 10:22 AM
