Old 07-03-2022, 03:14 PM   #1
sh0rtlife
I could be way out in left field and asleep at my post but I believe we are dealing with volume and velocity metrics. The MAF is sensitive to volume of air which is impacted by tubing diameter. It doesn't care about changes in velocity which would be altered by TB restrictions.
well i swappe d the pipe and havnt had any codes pop up..so we shall see
a TB is on my todo list as i want to lose the 10% throttle dead spot at the bottom and the slow response
Old 07-03-2022, 05:32 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
On the JDM market 3rd gens, they use the Lexus IS250/ISF gas pedal assembly(same part numbers) with an adapter bracket and that pedal assembly totally eliminates the annoying dead spot and makes the gas pedal even with the clutch and brake for easier heel toe downshifts.
All without having to fart around with getting the TB mod to play nice with the car.
I wouldn't recommend it if you're over 6ft tall though, you lose a bit of right leg room due to the gas pedal sitting higher than before.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
