Old 07-07-2022, 07:41 AM   #1
ShadowRabbit
Drives: 2008 Sedan
Originally Posted by sh0rtlife View Post
The link doesn’t work for me anymore. Does anyone else have the guide? I took a look at my 2008 sedan yesterday, and there were wires where I wasn’t expecting them (in the spots to put the wire to the ECU and the wire to ground) but I don’t have a wire coming from the ECU, so I don’t want to mess with it blindly. Thanks for any help!
ShadowRabbit is offline   Reply With Quote
Old 07-07-2022, 11:34 PM   #2
sh0rtlife
the website will sometimes "hiccup" try the link till it works...its still a good lin k i just double checked
wait if you have an 08 and it has the spots filled on the ECU than you dont need to run wires...your a plug n play..ie put in the CC unit and the jump cable at the snail, and verify the plug on the other side of the snail is in place
the link will clear that up about some of the 08+ cars having "most" of the CC stuff pre-installed to the point of only needing to plug the CC unit in and a matching cable..no "non factory" additions
Old 07-08-2022, 04:41 AM   #3
ShadowRabbit
Drives: 2008 Sedan
I’m so sorry! Let me try to clarify. I can see the thread, but the pdf link sends me to a French blog. I did find some other posts from before that guide was put together after searched a while.
So the wires I have are the blue and brown in the connector D3 under my steering column. What I do not have is a wire in the ECM pin 40 spot. I don’t know how to connect a wire from the ECM at this point, because I wasn’t expecting the wires that are in connector D3. I just don’t want to mess up my poor car, haha!
Newby MPG Questions (Look out!) Yaryaryaris Fuel Economy Forum 24 12-20-2009 10:09 AM
Newby questions re mods for towing noraebong Performance Modifications 7 11-18-2009 12:14 AM
Wheel balancing Alumimum wheels: CAUTION NEWBY tomjasz Cosmetic Modifications (Exterior/Interior) 3 08-20-2006 03:50 PM
