Old 07-07-2022, 11:34 PM   #6
sh0rtlife
Originally Posted by ShadowRabbit View Post
The link doesn’t work for me anymore. Does anyone else have the guide? I took a look at my 2008 sedan yesterday, and there were wires where I wasn’t expecting them (in the spots to put the wire to the ECU and the wire to ground) but I don’t have a wire coming from the ECU, so I don’t want to mess with it blindly. Thanks for any help!
the website will sometimes "hiccup" try the link till it works...its still a good lin k i just double checked
wait if you have an 08 and it has the spots filled on the ECU than you dont need to run wires...your a plug n play..ie put in the CC unit and the jump cable at the snail, and verify the plug on the other side of the snail is in place
the link will clear that up about some of the 08+ cars having "most" of the CC stuff pre-installed to the point of only needing to plug the CC unit in and a matching cable..no "non factory" additions
Newby MPG Questions (Look out!) Yaryaryaris Fuel Economy Forum 24 12-20-2009 10:09 AM
Newby questions re mods for towing noraebong Performance Modifications 7 11-18-2009 12:14 AM
Wheel balancing Alumimum wheels: CAUTION NEWBY tomjasz Cosmetic Modifications (Exterior/Interior) 3 08-20-2006 03:50 PM
