Old 07-12-2022, 01:45 AM   #1
sh0rtlife
honestly pinching the soft lines is BAD, and if you cant get the hard line off the soft line then goto the next joint and try it....id highly reccomend some croil or ...pb blaster to soak into it before trying to break it free..also...try to tighten it ever so slightly before trying to break it loose, the trick here is that it will free up the threads slightly
worst case...apply heat
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 09:50 AM
Drum brake problem. theb DIY / Maintenance / Service 4 04-23-2014 03:04 AM
Drum brake/parking brake devinlamothe DIY / Maintenance / Service 0 04-14-2012 09:30 PM
Anyone care to make a DIY on break flushing and bleeding? Hard_Yaris DIY / Maintenance / Service 19 05-04-2011 04:49 PM
