Old 07-18-2022, 12:44 PM   #1
BLH
Drives: 2007 Yaris Sedan
Not sure on a 2013,
On my 2007 with a Scan Gage reading water temperature.
It will not go into 4th gear until the water temperature is above 130 degrees F.
U340 transmission diagram shows the shift selector is an input to the ECM. Then there are electrical signals sent to the transmissions shift internal solenoids and it has an internal AFT temperature sensor in it also.
BLH is offline   Reply With Quote
About to replace the transmission fluid on an automatic 2008 yaris with 172kms jessesYaris General Yaris / Vitz Discussion 6 09-23-2021 04:51 PM
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
Automatic Transmission to Manual Zarkos Performance Modifications 3 05-22-2014 12:24 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
