![]() Drives: Yaris Join Date: Dec 2018
Bit late to the party but living in a rust prone area, will 44 ft lbs torque be enough with pretty weathered shock bolt and nut or should I loctite the shock nut on? Took quite a bit of work to get it off.
We are probably in the same rust belt. Looking at pics is tough but I think those threads are fine. Wire brush them a bit to get the gunk off, apply a little grease and spin the nut up and down the bolt a few times. Degrease the bolt and torque down the nut. 44 ft lbs is not really a great deal of torque and bolt will handle it just fine.
#3 | |
| Rear Sway Bar Instructions - Additional Pics | SeaYa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-26-2009 01:05 PM |
| TRD rear sway bar...street or race setting? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 02-08-2009 02:26 AM |
| TRD Rear Sway Bar Install ?? | bikegerm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 12-26-2008 01:46 AM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-05-2008 11:37 PM |
| DIY - TRD rear sway bar | kurokoma-kun | DIY / Maintenance / Service | 0 | 10-20-2008 01:21 PM |
