Old 08-12-2022, 08:13 AM   #1
moozart
Drives: Yaris 1.3 2010
Exclamation
I used the TechStream and managed to find the following code:
B1421 Solar Sensor Circuit (Passenger Side)
I also noticed that now always blowing hot air, and when the AC is on, it is colder.
Does anyone know if I need to disassemble the dash to replace it?
Thank you!
moozart is offline   Reply With Quote
Old 08-12-2022, 01:01 PM   #2
moozart
Thank you!
Just learned when you scan on a dark place this code can appear. After reset and trying on sun light it is gone.
But this problem is getting me crazy. I noticed when fan speed is low ( up to 4/10) it blows cold. When I set the fan speed to max it blows hot. But then even reducing to low fan speed, it blows hot still. Then I need to restart the car in order to have it cold again.
What is funny is when fan speed is above speed threshold (4/10) I hear a muffled noise and it turns immediately hot. As If the mix air damper shut and lock
I'm starting to think I have a bad control unit (my is automatic). I'll go to a shop next week.
Could the 07-08 yaris s front lips actually fits 2010 yaris? Adward10 Cosmetic Modifications (Exterior/Interior) 3 03-18-2013 12:06 AM
will 2010 Yaris wheels fit 2012 Yaris? yaris8888 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-24-2012 11:36 PM
Let's start a Yaris Club, each member has a specific number decal Yawesh General Yaris / Vitz Discussion 48 04-10-2009 10:49 PM
