![]() ![]() Drives: 07 AT & 08 MT Yaris HB 3dr Join Date: Nov 2021
2007 Vitz JDM folding mirrors
Does anyone have any experience installing JDM side folding mirrors? I did a search and could not find anything useful.
I was mostly looking for wiring instructions. My 2007 Yaris LB has the manual windows so no power anything. Before I purchase I just want to make sure I can even get them to work. Thanks in advance! |
pop the kick panel and have a look to see if you have the power hookup at all, if not youl be in for a bit o wiring shold be a bulkhead back there that makes everything plug n play..some have it.......some dont
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
Unless the gen 2s are all pre-wired for power mirrors like the gen 3s are, I hope you like wiring. lol
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's ![]() |
It's too bad the MicroImage site went tits up. We had a member in Guelph who did it to his 2010. There had been an excellent write-up on the project. It was a significant challenge is all I can remember.
let me preface this by saying i have no idea what those mirrors are or how they are wired
with that said i have added power mirrors, door locks and even power windows to cars that never came with them and were never wired for them the biggest issue with mirrors(and this is a generalization) is that you need to have a semi matching switch...IE if its a 5 wire setup then you need a 5 wire switch...ive seen some weird units where they have mmulti pole motors and alot more wiring involved your typical mirror works in 2 motor setup 4 wires in total there is no "ground" the switch is your ground and you run all 4 wires from the motor back to the switch, and you power and ground the switch and then draw power from a fuse and chassis the ground...teh switch itself powers one wire and grounds the matching wire, this can all be figured out in short order with a multi meter so long as your comfortable running wires its not useualy a big deal worst one i ever did was power windows into an 86 civic from an accord....that was a brutal one..the holes in the doors wernt even the same |
To give you all an idea of what I am talking about.
if you pop off the painted cover to expose the wiring at the individual parts figureing it out should be a breeze
is the light a single turn signal or is it a combo marker/signal? |
![]() ![]() Drives: 2009 Yaris 2dr Liftback Join Date: May 2019
I don't have experience with the JDM power folding mirrors. However, I can confirm that adding replica power mirrors to a USDM 2009 yaris is as simple as buying mirrors *with the motor pre-installed* and an OEM power mirror switch and installing them. My car was pre-wired between the mirrors and the switch which is located under the driver side AC vent.
*EDIT* |
Good question, I know they are signal, but not sure about marker. I'd have to do some digging. From a cursory look, they were only released to the Asian market, most of these I've seen have come out of Thailand.
#10 | |
Thread Tools | |
Display Modes | |
JDM folding mirrors with signals............ | 3cyltrbo | Cosmetic Modifications (Exterior/Interior) | 22 | 08-01-2016 06:34 AM |
FS: JDM Vitz RS Front (2009) and Rear (2007) Bumper (AZ and Possibly So Cal) | jmew0ng | Items for Sale by private party | 23 | 10-05-2013 12:24 AM |
WTB: JDM Power folding mirrors | BlazingBlue08HatchBack | Items for Sale by private party | 0 | 04-10-2007 05:31 PM |
