Old 08-20-2022, 01:36 PM   #1
TommyWasabi
Drives: 07 AT & 08 MT Yaris HB 3dr
Originally Posted by redwolf1973 View Post
Hi all! I want to replace the headlight assemblies on my 2010 Yaris liftback. If I do so, will I have to re-aim the headlights or won't the aim be affected? TIA!
Before you install the new headlight assemblies, park in front of your garage with your lights on and mark on the garage where the beams hit with painters tape. After you install the new assemblies, turn on your lights and see if the beams hit the same area where you previously marked. Make adjustments as necessary.
TommyWasabi is offline   Reply With Quote
Old 08-20-2022, 04:30 PM   #2
redwolf1973
Drives: 2010 Toyota Yaris
So that is an affirmative?
But really thanks! That is a great tip! My headlights are yellowed (I'm guessing) on the inside since I used plastic polish and it didn't help. Anybody ever see cool looking headlights for a 2010-ish Yaris hatchback?
redwolf1973 is offline   Reply With Quote
Old 08-20-2022, 08:24 PM   #3
TommyWasabi
Not necessarily, that's why you check first. Sometimes the new assemblies will be spot on, sometimes not.
Replacement time, and brake bolt rubbers question BennyLava DIY / Maintenance / Service 11 08-27-2016 07:26 PM
Replacing headlight bulbs in under 5 minutes without removing the bumper 07liftback DIY / Maintenance / Service 0 01-23-2015 11:11 AM
Is it possible to replace just the lense on the headlight assembly? firebird1999us Cosmetic Modifications (Exterior/Interior) 10 09-12-2014 10:54 PM
OEM Toyota HID Headlight Assembly - Where to SOURCE? bigsky2 Cosmetic Modifications (Exterior/Interior) 18 12-21-2006 05:01 PM
Quick headlight question silverRS Cosmetic Modifications (Exterior/Interior) 3 06-21-2006 09:54 AM
