#12 | |
![]() ![]() ![]() Drives: Yaris manufactured after 2007 Join Date: Nov 2010
As I said in my previous post, I think I'll also put an artificial ice/heat packet inside the envelopes and wrap it all in aluminum foil to moderate the temperature. "Ideally" it should be stored at 70 degrees F (21 C), very difficult in a car. But it is rated to 265 degrees F (130 C)-- explosion could occur over 265 degrees F (130 C), but the temperature inside of a car will not get that high just from being in the sun. And the temperature in the spare tire compartment will be even lower than in the car. And as I said in the previous post, I am going to attach a strip of reflectix to the bottom surface of the spare tire compartment cover to keep the spare tire compartment even cooler in the summer. The SJ 1329 jumper can be charged while driving using a male to male 12 volt charger cable. But, according to the instructions, you're not supposed to charge it for more than 30 minutes or leave unattended when using the 12 volt charger cable -- it could explode. And it looks like it can be charged while driving using an inverter (I have a small 75 watt inverter) and an extension cord without the 30 minute limit and caution, since it can be recharged from a 120 volt wall outlet. It is supposed to be recharged once a month or after each use as a jumper (or other use -- it has a 12 volt outlet and an LED light). Thanks again, R. Last edited by RMcG; 08-25-2022 at 12:29 AM. |
| Tags |
| jump, lead-acid, lithium, starters |
| Starter Problems - Heads Up | tmontague | DIY / Maintenance / Service | 6 | 03-01-2019 10:04 AM |
| Noobie Advice Needed | ianmak | UK | 7 | 10-17-2017 02:00 PM |
| Advice on wheel spacers and sway bars needed! | Lars | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 12-05-2013 11:28 AM |
| Bazooka A100 subwoofer install advice needed | LugNut | In Car Entertainment + Electronics (audio / video / alarm) | 9 | 07-09-2012 11:02 PM |
| Yaris 06 T Spirit advice needed ! | nocturne_sa | General Yaris / Vitz Discussion | 1 | 01-03-2010 05:24 AM |
