Old 09-11-2022, 12:53 PM   #1
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
2ZR-FE and 2ZR-FAE engines have different harnesses and ECUs. One madman has done an FAE swap into a 3rd gen but its quite a bit more involved than the 2ZR-FE and the power difference between the two is ~10 horsepower.
Look for a 2ZR-FE.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
Old 09-11-2022, 02:47 PM   #2
TommyWasabi
Drives: 07 AT & 08 MT Yaris HB 3dr
Originally Posted by stidnam View Post
It depends. Are you just looking to use the basic engine assembly, or are you trying to use the computer, loom, ancillaries etc? If the later, be careful as there are various iterations of the 2ZR with late model engines and associated electronics most likely incompatible with earlier year cars.
Look for a 2ZR-FE.
Yeah, from what I have read here in the forums, the two iterations to be aware of are the 2zr-fe and the 2zr-fea. The -fe version being the one that most have swapped and is the version I am going to attempt since there is quite a bit of documentation on it.
My main issue is are the -fe versions (non -fea) the same? It is just easier to find a later model -fe motor with low miles in the junkyards in my area.
From my reading the xd parts are the hard ones to find.
TommyWasabi is offline   Reply With Quote
Old 09-11-2022, 05:05 PM   #3
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
As far as I know, nothing changed that would be a hinderance to swapping in a 2ZR-FE throughout the years we got the engine.
2014 NCP131 5 Speed
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
3rd gen engine swap, 2ZR? 2AR? Swap newbie m.flores.0928 Third Gen Yaris General Discussion 6 10-02-2020 10:54 AM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 08:12 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
