Old 09-12-2022, 06:36 AM   #1
stidnam
Drives: Starlet
You generally want to ensure that the engine you're swapping comes from the same generation/era as the car you're swapping it into.
I've talked at length with said "madman" about his 3rd gen swap. He ran into a lot of the same issues I did, including the Yaris ABS unit being incompatible with the engine ECU. He really had no other choice with that swap btw. You can't swap earlier model 2ZR setups into 3rd gen Yarii. Technically you can get the motor to run, but there are incompatibilities with body modules, immobilisers, dash clusters etc.
Based on the above and my experience, I do not believe a late model 2ZR engine would work in an early model Yaris such as the NCP9X. Not seamlessly anyway.
stidnam is offline   Reply With Quote
Old 09-13-2022, 06:14 PM   #2
TommyWasabi
Drives: 07 AT & 08 MT Yaris HB 3dr
This is interesting. So in short, you are saying a 2017 2ZR engine wouldn't be compatible with the 2007 Yaris while utilizing the xD ECU/engine harness etc. Is this because of the progress in the electronics? I'm just trying to understand what the major differences would be between the earlier 2ZR motors vs more recent years.
TommyWasabi is offline   Reply With Quote
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
3rd gen engine swap, 2ZR? 2AR? Swap newbie m.flores.0928 Third Gen Yaris General Discussion 6 10-02-2020 10:54 AM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 08:12 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
