Old 09-14-2022, 12:29 AM   #1
stidnam
Drives: Starlet
It depends. If it's a valvematic engine, I doubt it'll work as the engine won't run properly without the computer which isn't going to be compatible with the 2007 electronics. Did you guys get a 2017 model 2zr without valematic?
If the engine isn't valvematic, it may work if you have all the XD electronics. It also depends on whether the intake manifold has ACIS, but that would be fixable by swapping manifolds. I don't know if you guys got ACIS...?
stidnam is offline   Reply With Quote
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
3rd gen engine swap, 2ZR? 2AR? Swap newbie m.flores.0928 Third Gen Yaris General Discussion 6 10-02-2020 10:54 AM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 08:12 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
