Old 09-15-2022, 12:09 PM   #1
remcafee
Originally Posted by stidnam View Post
For the record I can say with 100% certainty that the 2zrfe in Australia received ACIS from 2013 onward. Was actually a pain in the arse as the intake manifold did not clear the Yaris radiator fan shroud due to the extra bulk in the intake. The entire overflow bottle had to be cut off from the shroud and the shroud modified to clear the intake :(. Anyway, won't impact you guys :)
ahhh so the 2zrfe engine does have the acis then? not only the 2zrfae? it explains the intake manifold goofiness that i see when i work on corollas and i see some differences in the intake manifold design, there is also a recall that updated the intake manifold for the vaccumm booster libe freezing up or something, so i guess you can always get the intake manifold you want later if the motor you get doesnt have the correct one.
Old 09-15-2022, 03:02 PM   #2
TommyWasabi
Drives: 07 AT & 08 MT Yaris HB 3dr
So you've seen Corolla's with the ACIS in the states? Interesting, from stidnams comments I was on the path to thinking that this might be something that only the overseas Corollas had. I'll keep digging. This has peaked my curiosity. I wonder if there is a way that we could figure out which ones had it and which ones did not and why.
TommyWasabi is offline   Reply With Quote
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
3rd gen engine swap, 2ZR? 2AR? Swap newbie m.flores.0928 Third Gen Yaris General Discussion 6 10-02-2020 10:54 AM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 08:12 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
