Old 10-10-2022, 04:57 PM   #1
Neinris
Originally Posted by remcafee View Post
you will also need the e brake cables, brake lines (flexible and hard lines on rear axle), backing plates, and i would get new rear axle bushings while you are doing that work
Would you happen to know the PN for the hard lines for the rear?
Old 10-12-2022, 04:05 PM   #2
remcafee
47323-0d201 and 47324-0d201 are the part numbers for the left and right hard lines.
Tags
brakes, ncp90, trd yaris, upgrade, vitz rs
5 Lug Conversion DarkShadowFox Wheels, Tires and Suspension Forum sponsored by The Tire Rack 60 05-18-2018 02:33 PM
Rear SE axle beam swap yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 25 09-24-2017 11:26 PM
60/40 split rear seat swap question jayeh Cosmetic Modifications (Exterior/Interior) 12 10-28-2012 03:07 AM
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 06:13 PM
