Old 10-11-2022, 05:23 PM   #1
Looks like the tips are making contact with the bumper. If it hasn't already happened, you will melt the plastic. Otherwise, that looks fantastic.
Old 10-11-2022, 08:46 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Hey man! Thanks! Actually, they're about 1 cm from the bumper, although they look like they're touching. So far, no evidence of melting or heat damage. It's funny...about 70% of the exhaust comes out of the right tip. It can be quite warm after a boost, whereas the left side, you could keep your hand on it.
Old 10-13-2022, 11:38 AM   #3
Neinris
Drives: 08 Yaris 3 Door Hatchback
I'm guessing that the two mufflers' piping are not equal length from the Y and/or one's straighter than the other.
I wonder if you should install a flap in line which closes the right exhaust, until you hit higher RPM? I've seen it on BMWs and even Toyota Camry, where the straighter pipe exhaust has a flap that opens and closes depending on the RPM. I guess it's the remedy for "Back Pressure", but your turbo don't need that.
Neinris is offline   Reply With Quote
Old 10-14-2022, 06:02 AM   #4
06YarisRS
Yes, you are correct in your description of the current configuration. It doesn't cause any issues that I am aware of, so I likely won't do anything more to it. Interesting info on the flap system. I plan to read on that a bit. Thanks!
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 10:36 PM
