Old 10-11-2022, 08:46 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Looks like the tips are making contact with the bumper. If it hasn't already happened, you will melt the plastic. Otherwise, that looks fantastic.
Hey man! Thanks! Actually, they're about 1 cm from the bumper, although they look like they're touching. So far, no evidence of melting or heat damage. It's funny...about 70% of the exhaust comes out of the right tip. It can be quite warm after a boost, whereas the left side, you could keep your hand on it.
Old 10-13-2022, 11:38 AM   #2
Neinris
Drives: 08 Yaris 3 Door Hatchback
I'm guessing that the two mufflers' piping are not equal length from the Y and/or one's straighter than the other.
I wonder if you should install a flap in line which closes the right exhaust, until you hit higher RPM? I've seen it on BMWs and even Toyota Camry, where the straighter pipe exhaust has a flap that opens and closes depending on the RPM. I guess it's the remedy for "Back Pressure", but your turbo don't need that.
Neinris is offline   Reply With Quote
Old 10-14-2022, 06:02 AM   #3
06YarisRS
Yes, you are correct in your description of the current configuration. It doesn't cause any issues that I am aware of, so I likely won't do anything more to it. Interesting info on the flap system. I plan to read on that a bit. Thanks!
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 10:36 PM
