Old 10-13-2022, 10:58 AM   #1
Neinris
Originally Posted by remcafee View Post
47323-0d201 and 47324-0d201 are the part numbers for the left and right hard lines.
Thank you Remcafee... well fudge, I thought I found the correct part numbers. Would you be able to tell me what 47323-52110 and 47324-52100 are? Because those are what I ordered.
to be honest, the brakes dont necessarily change the stopping distance in my opinion, the thing i noticed most is more instant bite when you hit the pedal and less brake fade when you are 5+ laps in on a track the pedal does not get spongy.
tires are what affects your stopping distance in all reality
Tires will definitely help your stopping power, no argument there.
In my experience, since my DeeDee (Yaris) don't have ABS, I've locked my front wheels more than a few times, due to my rear drum brakes fading, going down a hill and suddenly stopping at a traffic light. I believe its the rear brakes, because they were great for the first 6 months when I first replaced them, never locked my wheels and they supposedly should last longer than the front disc because the front brakes takes most of the weight and beating. It's starting to get colder here in MD and it seems to be helping cool the drums which have prevented me from locking up, or maybe it's just my imagination.
DeeDee is the third car I've owned without ABS. First was a 1973 VW Beetle, which I bought to learn how to drive a manual, it had 4 drum brakes!!! I locked the front wheels often because she just wouldn't stop sometimes, I later found that the previous owner had plugged the hole in the brake fluid reservoir leading to the rear because there's a leak somewhere in the hardline going to the rear. The second car I owed that didn't have ABS was a 92 Prelude, which had all disc brakes. I only locked up the wheels a couple of times when I first got her, before I've learned how to control my braking with that car. I was a lot younger then and more aggressive driver then than now.
So I'm definitely onboard with getting all 4 disc brakes.
I hope someone found my experiences useful.
Old 10-15-2022, 03:55 AM   #2
remcafee
hmmm it appears those part numbers are a production change effect i am 90% sure they are the same just when toyota changes faciltys or part manufacturers they change the part number, im sure they are the same if not very similar, might have some different inspection paint marks and could be a different color, toyota always changes up the fine details like that, its rather annoying if you ask me but it is what it is.
Tags
brakes, ncp90, trd yaris, upgrade, vitz rs
5 Lug Conversion DarkShadowFox Wheels, Tires and Suspension Forum sponsored by The Tire Rack 60 05-18-2018 02:33 PM
Rear SE axle beam swap yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 25 09-24-2017 11:26 PM
60/40 split rear seat swap question jayeh Cosmetic Modifications (Exterior/Interior) 12 10-28-2012 03:07 AM
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 06:13 PM
