Old 10-18-2022, 12:44 PM   #1
sh0rtlife
ive considered snagging similar parts out of japan as i noted some of those cars wearing 14s with rear disc..to which i was shocked
can you confirm?
Old 10-18-2022, 12:56 PM   #2
remcafee
can you confirm?
i will see if i can find a 14" wheel at my work and try test fitting on my car, dont get your hopes up though as 14" wheels are hard to see around here with an array of minivans and crossovers here at my shop
Old 10-18-2022, 01:24 PM   #3
Neinris
can you confirm?
I’m not sure if 14s will fit, not for the front anyway. I imagine if you have rear disc brakes then your front rotors are bigger. I have the SE rotors upfront, and they barely fit 15s.
File Type: jpg 47B17B19-B080-4825-B262-DD67B0BFB190.jpg (149.7 KB, 98 views)
File Type: jpg 1D4DA93B-3928-4E2B-A82D-57FB3C61FF71.jpg (79.0 KB, 90 views)
Tags
brakes, ncp90, trd yaris, upgrade, vitz rs
5 Lug Conversion DarkShadowFox Wheels, Tires and Suspension Forum sponsored by The Tire Rack 60 05-18-2018 02:33 PM
Rear SE axle beam swap yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 25 09-24-2017 11:26 PM
60/40 split rear seat swap question jayeh Cosmetic Modifications (Exterior/Interior) 12 10-28-2012 03:07 AM
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 06:13 PM
