Old 10-31-2022, 04:03 PM   #1
Neinris
Originally Posted by enviri View Post
just look out for rear beam slapping your chassis over time once its all settled now that you swapped bolt positions, and you are good to go
I've never had this issue, and I've had this setup for over a year now. I even had my whole family ride this weekend, wife in the front passenger seat and the two kids in the back. I'm around 180lbs, my wife's around 90lbs, my 10 year old son who sat behind me is about 70lbs, and my 16 year old is about 150lbs. We went over some dips and bumps, I didn't hear or feel any slapping of the rear axle beam on the chassis. I'm on Tein S. Tech lowering springs, and still stock shocks on the back, Bilstein B8s struts up front.
Old 11-01-2022, 12:48 AM   #2
Compeer
Drives: NCP90 TRD Yaris Manual
I had the entire rear subframe, 2 tonne jack, front old hubs and, springs shocks and jack stands and tool box in the back after i was done and just check no marks from slappage, so Idk it had like twice the weight in the rear and didnt touch. If it does i will buy the stick on rubber pads.
Compeer is offline   Reply With Quote
Tags
brakes, ncp90, trd yaris, upgrade, vitz rs
5 Lug Conversion DarkShadowFox Wheels, Tires and Suspension Forum sponsored by The Tire Rack 60 05-18-2018 02:33 PM
Rear SE axle beam swap yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 25 09-24-2017 11:26 PM
60/40 split rear seat swap question jayeh Cosmetic Modifications (Exterior/Interior) 12 10-28-2012 03:07 AM
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 06:13 PM
