Yes my problem was the MAF sensor. Do you get YouTube? There’s a mechanic named Scotty on YouTube who has all kinds of videos about car problems. You might search your area codes on YouTube for suggestions.
#2 | |
Martinios
Drives: Toyota Yaris MK2 1.3 T3 2006 Join Date: Feb 2022
![]() Yes, I have seen some of Scotty's vids on YouTube - he is quiet useful.
Tired of German cars and the black art of TDI mechanics...
#3 | |
Martinios
SCOTTY FIX RESET ECU CURED LIMP MODE?
- that is until I tried Scotty Kilmer's YouTube Toyota ECU Reset Fix. It may have finally cured the problem! https://www.youtube.com/watch?v=F6pMlbNW7-E Basically: (With Key Off) 1. Disconnect BOTH Battery cables , starting with Negative. 2. Short the + and (-) cables together using a wire and croc clips for a few minutes 3. Put the sidelight switch on to drain any remaining charge in the ECU 4. Turn lights off, reconnect Battery cables, starting with positive, and leave for a few minutes. 5. Start Engine and idle at 2,000 revs with things turned on as you would normally drive , i.e A/C or sidelights etc. for a few minutes (Scotty says 5 min, I did 3 min) 6. Allow idle to drop to normal, then idle again at 2,000 rpm again for a few minutes with no load on (from lights, A/C). While the Battery was off, I also unplugged the sockets to the ECU (after a few minutes) and sprayed the plugs with WD40 , then reconnected them. (This was an awkward job in itself, but I won't go into details here). I thought I might have a bad connection or corrosion as the fault codes always said 'Powertrain...' Anyway, Yaris is running good now and I have along trip ahead this Sun, thanks ![]() Can't believe Car Makers allow their products to be this tempermental!
| Tags |
| limp mode, throttle body |
| Starting problem | Muz | Suggestions - Feedback - Questions | 2 | 05-06-2017 05:31 PM |
| Warrany Service Problem? | 2009Yaris | General Yaris / Vitz Discussion | 4 | 03-31-2011 04:56 PM |
| Problem with my car | rakhan01 | DIY / Maintenance / Service | 8 | 12-03-2010 05:12 AM |
| Toyota C160 Reverse Gear Problem | Parmas | DIY / Maintenance / Service | 2 | 12-01-2010 01:30 AM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 09:12 PM |
