Old 11-04-2022, 02:44 PM   #1
sh0rtlife
so how much total extension did you get...pictures dont tell the whole store a si know wheels dont "bottom out' on most spacers...looks like about 1 inch looking at the spacer but installed it looks like 3+
theres a dozen other ways to acomplisht this (quick release wheel).....my concern has always been if i stretch the wheel..hows entry/exit on a 5dr.
thankfullly im long armed so its not terrible...its not great but liveable
wifes kinda wanting an aftermarket wheel on there anyway...which helps that "depth" issue some
Old 11-04-2022, 02:58 PM   #2
Kasbien
Kasbien's Avatar
Drives: 07 Sedan (AT)
The purpose of this route is to retain the stock steering wheel and air bag setup, which is what I wanted. If you don't care for either of those then by all means buy an aftermarket wheel and hub.
The Spacer Shop extension is comprised of two pieces, totalling 5cm/2" of extension. It makes a big difference. But this is only if you're able to modify the kit to work that should work right out of the box. I am highlighting that for others.
Kasbien is offline   Reply With Quote
Telescopic steering column extension length? Micropurchase Australia 3 05-27-2012 03:38 AM
Steering wander, adjusting EPS assist Snubba Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-22-2012 05:39 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
