Old 12-29-2022, 07:59 AM   #1
bronsin
bronsin's Avatar
Originally Posted by sh0rtlife View Post
i cant help but wonder if some of the canadian units didnt have it..easpecialy "early" 09's
isnt there a relay or fuse you can pull to dissable the abs?
honestly im tickled pink mine DOESNT have ABS....and so long as your not just jambng on the brakes works great in the snow and ice...TIRES ARE EVERYTHING!
Statistically ABS Has made no difference in the number of accidents or fatalities.
In fact some studies indicate those things go up because people are overconfident and drive faster than they should. They think ABS will save them.
Old 12-29-2022, 11:23 AM   #2
sh0rtlife
YUP ditto for all the other fancy "anti-insert object here"
i adore the fact the yaris ive got doesnt have ABS..and curse the ABS thats on the explorer that is VERY effective at trying to put you in a ditch in gavel and snow...the f350 SD i used for a many years couldnt be trusted when the weather turned, between the abs and the traction control it was nothing but a ditch finder...meanwhile my 89 caravan was a rented mule that could be driven HARD without a care in the world..no abs
ABS Code Keeps Returning After Sensor Replacement Code 31 Front Right Chwbcca DIY / Maintenance / Service 5 09-15-2021 08:16 AM
First Generation Vitz ABS Issue Owais Yunus DIY / Maintenance / Service 0 10-29-2016 11:14 AM
Noise From ABS when Braking + ABS & (!) Light On - Please Help Chris Jackson DIY / Maintenance / Service 2 04-23-2016 12:00 AM
ABS not working on 2003 Yaris harriss UK 0 02-20-2011 05:24 AM
What's with ABS? jgag123 Canada 9 01-01-2009 06:04 PM
