Old 01-04-2023, 05:49 PM   #1
Type-Y
Drives: 2007 Yaris hatch
Originally Posted by Compeer View Post
You can buy adjustible sway bar links, I would buy a set of these and adjust them to same exact length as the tiens were. Also do a google search by length of your swar bar. +/= 5mm will still fit just cant be too far off or itl have incorrect angles.
something like these https://www.motionmotorsport.net/pro...y-bar-endlinks
I have the Tien flex Z coil overs so if they ever stuff out i will be in the same boat so if you find a standard link thats the right size post your part number otherwise the adjustibles will do.
Thanks for your suggestion, much appreciated. I can't find the specs on what lenghts there are on the motionmotorsports part.
Originally Posted by sh0rtlife View Post
find a "good" hardware store and you can get the ball ends and rod and make your own for a fraction of the cost...been there done that on a handfull of cars where the new bar made to fit doesnt match up with the OE links and somethings gotta be fabbed
personaly i go for the "open ball"(spherical ends) type vs the "ball-joint" type as you then get a nut/bolt assy and you can collar or machine a bolt to fit your application with perfection..even spacering out should you need a lil clearance ...sometimes finding the rod can be tricky but mcmaster car has it if you cant find it localy
FWIW the balljoint type of rod ends in that link are identical to parts used on some treadmills and ive got a handfull of em LOL
LoL, I like the possibility of that budget friendly suggestion
After a bunch of searching, including reaching out to Tein (still waiting for them to get back to me). I found, a Tein adjustable sway bar link on ebay that should fit. My links are 12.5 inches bolt to bolt and this one should fit, since it has an adjustability range from 290-350mm :
https://www.ebay.com/itm/19486331105....c101110.m1982
Its kind of pricey, but should fit. I'll probably order this. Just waiting to hear back if these are sold as a pair or if the price is for a single unit, which woudl be F-ing nuts.
I also found it at Vivid Racing for a better price:
https://www.vividracing.com/tein-swa...155247546.html
Last edited by Type-Y; 01-04-2023 at 06:49 PM. Reason: Found additional information
Type-Y is offline   Reply With Quote
Old 01-13-2023, 07:21 AM   #2
Compeer
Drives: NCP90 TRD Yaris Manual
I will measure the tein links when i pull my adjustible setup back off for my warrant of fitness check in next week or so and will post exact length you need.
Compeer is offline   Reply With Quote
Old 01-13-2023, 03:08 PM   #3
Type-Y
I heard back from Tein and they sent me the part number.
SPS23-R5916
They are $26 each.
Old 01-13-2023, 05:13 PM   #4
Compeer
SPS23-R5916
They are $26 each.
My original Tein flex z links are marked 913 and are 300mm long, the original links that came with my trd shocks and springs are 360mm. The advance Z must be taller than the Flex z I own.
[IMG]https://i.gyazo.com/1fa121a03cdc24956781d57355e5a038.jpg[/IMG
I made another post to document the Link sizes, if you could measure the links when you get yours as well and post them there that would be awesome.
Old 11-03-2023, 12:42 PM   #5
Type-Y
Its been a while. Still have the Yaris.
I ended up using the Tein adjustable links:
SPS23-R5916
These worked well, though they were more expensive.
Tokico blue or ksport coilovers? Caramanos2000 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 03-11-2016 09:35 AM
FS: Tein S-Tech Lowering Springs / Tokico Blue Struts & Shocks DPS Items for Sale by private party 18 10-09-2014 10:35 PM
FS: Tein S-Tech Lowering Springs / Tokico Blue Struts & Shocks Freestylin Items for Sale by private party 21 02-04-2014 07:33 PM
TEIN - Basic Coilovers *Now Available* EnduroMTS Sponsors Classifieds Area 4 10-13-2006 02:43 PM
TEIN Basic coilovers C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 06-26-2006 01:57 AM
