Old 01-18-2023, 10:29 AM   #1
mr9865
$10.25/hr frying chicken
mr9865's Avatar
Drives: 2012 Yaris L
I'm at 160,000 on the original plugs, maybe i should change them?
mr9865 is offline   Reply With Quote
Old 01-18-2023, 11:53 AM   #2
Compeer
Drives: NCP90 TRD Yaris Manual
Iridium plugs don't melt the tips like copper plugs do, You can clean them check the gap and if they look mint they are mint.
We changed out copper plugs at 30k because they slowly burnt the copper tips away, iridiums melting tempture is so far above the engines combustion tempture you could melt the entire engine down and the irdium tips would still be intact.\
So at 100k you can clean them, regap them and if they dont look damaged reinstall them, Ive heard of people doing 300k km on them and they are mont as long as they are cleaned and gap checked every service.
In saying that I run one step colder plugs NGK bkr6eix-11 since I live in the heat and like to give her shit, she runs mint on them.
NGK and Denso are both japanese made quality plugs that provide OEM plugs to japanese companies, if Denso is out of a plug they install NGK and vice versa in japanese cars.
Compeer is offline   Reply With Quote
Old 01-18-2023, 12:01 PM   #3
sh0rtlife
100-150k is useualy when the OEs start failing in most cars...asuming we are talking miles not kilometers lol
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 02:07 PM
Where do I buy ngk iridium tip 7 heat spark plugs? PETERPOOP Performance Modifications 23 03-08-2009 08:34 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
Dual ground electrode spark plugs Kitt DIY / Maintenance / Service 15 02-09-2009 11:08 AM
Spark Plugs YamilR DIY / Maintenance / Service 2 09-28-2007 08:38 PM
