Old 01-22-2023, 01:55 PM   #1
sh0rtlife
the correct fix for this is to remove some of the OE seam sealer (wherever and everywhere its cracked)with either a knife or a cutoff wheel to widen the crack, at which point you get some 3M "seam sealer" and re-apply as the factory did..this will perminantly fix the problem for another 20 years
Old 12-17-2023, 02:47 AM   #2
alex_melodymaker
Drives: 2008 Liftback/Black/5-speed MT
Hi, when you mentioned removing the OE seam sealer, would that be in the gutter where the removable rubber drip molding sits on the edges of the roof outside?
alex_melodymaker is offline   Reply With Quote
Old 06-27-2025, 12:27 PM   #3
dusky5346
Drives: Yaris 2008 Hatchback
Hi, can you show a picture where and how to do this please? understanding english is very dificult to me and im having the same issue
thanks in advance
dusky5346 is offline   Reply With Quote
Leaking rear wheel cylinders? xdarkxfirex DIY / Maintenance / Service 8 04-11-2017 02:47 PM
Chrome pillar trim for 3 dr Foot Cosmetic Modifications (Exterior/Interior) 3 01-26-2013 04:09 PM
Water Leaking into car! CKaelin General Yaris / Vitz Discussion 18 08-16-2012 01:53 AM
Axle seals leaking caused by lowering ride height? NH3R717 DIY / Maintenance / Service 2 07-22-2010 03:29 PM
Fishing an AV wire down B pillar redyaris In Car Entertainment + Electronics (audio / video / alarm) 6 03-10-2007 06:17 PM
