the coolant is bright pink and gets crusty when the water has evaporated out. the main thing is to check the water pump, as they leak all the time. then take a flashlight and look at everything that has coolant in it. look for the crusty-ness. there is a blue fluid that checks for internal head gasket leaks. (coolant-to-oil leak) you can get from an auto parts store; it has a suction bulb that you attach to your radiator. it pulls the vapor of the coolant through the blue fluid and the fluid turns green with the presence of hydrocarbons. (fuel/oil contamination) also remember coolant will evaporate over time. it will become acidic over time. change your coolant every 3 years.
DO NOT USE STOP-LEAK!!!!! never use any kind of stop-leak in any kind of system ever! (coolant, oil, transmission, a/c, etc.) stop-leak is a terrible product that causes more problems than it will ever fix. only in an extreme emergency situation should it be considered. fix it right, or don't fix it at all. |
| Cool race video. | Palmer812 | Photo-Video-Media Gallery | 4 | 03-23-2010 09:08 AM |
| New Yaris Owner Wondering: Cool Engine Indicator: Normal? | msmitka | New YARIS Purchase Forum | 27 | 12-17-2009 08:10 PM |
| Goodwood Revival - pretty cool old engines! | tomato | Off-topic / Other Cars / Everything else Discussions | 13 | 09-02-2009 02:35 AM |
| Can i drive when the COOL indicator light is on? | hans_fh | General Yaris / Vitz Discussion | 22 | 11-07-2006 10:05 PM |
| Top 10 Cheap Cool Cars for Teens for 2006 | hhcchen | Off-topic / Other Cars / Everything else Discussions | 21 | 06-04-2006 05:36 PM |
