Old 01-24-2023, 06:50 PM   #1
Neinris
Personally I use this calculator instead:
https://www.wheel-size.com/calc/
Not only does it show the tire size, it also shows necessary offset.
What I didn't see mentioned are the supposed stock wheel/tire sizes of 175/65/R14 = 23 and 185/60R15 = 23.7
I discovered that there are two different speed sensor gears, mine has the one for 175/65/14, so my 185/60R15 tires makes my car go faster than what's indicated on the gauge cluster.
Use the calculator provided to get to the closest stock tire size. If you want to get better gas mileage, get a bigger diameter wheel/tire combo. For acceleration, smaller diameter.
Old 01-25-2023, 12:54 AM   #2
Compeer
Drives: NCP90 TRD Yaris Manual
If i remember correctly the car had its ECU changed to suit the wheels at factory. With the right scan tool i was lead to believe you can change the speedo to suit the new wheel size. Could be wrong with the yaris tho but i know other cars you can do this.
Compeer is offline   Reply With Quote
Old 01-26-2023, 07:09 AM   #3
Neinris
Actually, it’s not my ECU/ECM, because I have a smart ODB gauge plugged in, which I can adjust the speed it displays, but I have it set to 100% and the speed it displays is accurate when compared to my GPS and the speed RADAR that I pass by on the way to work.
Old 01-28-2023, 04:31 AM   #4
Compeer
My obd2 display shows same as my speedo is reading, I have the JDM RS vitz dash installed that did not come with the car and I changed that second day I owned it so this could also be why mines a bit off.
